There appears to be a minor bug in the Tree "Get Child" method in LV 7.1. If the "tag" input does not exist in the tree, but the method output is not wired out, no error is returned. However, if the method output is wired to an indicator, error 1136 is returned. I haven't tried this on any other methods or controls. (I was hoping to use this method to determine if a tag already exists in the tree).
I've attached a demo VI. Run it once as-is, and you'll see that no error is returned. Then go to the block diagram, right click on the invoke node "Navigate Tree:Get Child" output, and select Create-Indicator. Run the VI again and you'll see error 1136 reported.
