LV 7.1 and LV 8.5 both installed at one computer
Smiley Very HappySmiley Very HappySmiley Tongue
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 11 of 15
(731 Views)
So i understand that if i willl install Traditional DAQ from LV 8.5 CD (recent version 7.4.4) it will be compatible with LV 7.1 and 8.5 both. Now i'm goint to try it and will write you effects of this operation 🙂
Message 12 of 15
(719 Views)
Good Luck,post ur results.Smiley Wink
Balaji PK (CLA)
Message 13 of 15
(717 Views)
Ok, I did it and...
At first look everything looks good, but i had a problem with application written in LV7.1 and built in Application Builder - my DAQ didn't work properly. I experienced problem with signal generation and acquisition.
I completly removed NI products and installed only LV 8.5 and Run-Time 7.0.0 so now every my application works good.
And cocnlusions - finally i don't know if it's ok to have both installed LV 71 and 8.5 🙂
I think, if i had more time, my DAQ will be work. But more elegant solution is to have recent LV installed and eventuality properly Run-Times to run builded applications.
Message 14 of 15
(675 Views)
Thanks for the experimented results
Balaji PK (CLA)
Message 15 of 15
(673 Views)
