LV 7.1 and LV 8.5 both installed at one computer
Is it possible to install both LV 7.1 and 8.5 on one computer with Windows without any problems?
Kacper
Message 1 of 15
(4,371 Views)
On my computer I am running 7.0 and 8.6. All labview versions are installed to separate dirs. I can run both version at the same time no problem. But I have a very clean installation. I do not know what happens if you want to run say DAQ applications, and other software that need NI drivers. You may run into compatibility issues.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 15
(4,366 Views)
Ya u can Install both LV 7.1 and 8.5 on same comeputer witout any issues.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 3 of 15
(4,365 Views)
That's good info. But if i want to use Traditional DAQ in 7.1 and DAQ-mx in 8.5 what i need to do? Now i have 7.1 installed, and i'm going to install 8.5. Could I install Traditional DAQ from 8.5 or leave this option unchecked? Does Traditional DAQ form LV 8.5 CD will be work with installed 7.1. Could I install things related to 7.1 (support, run-time, etc.) from 8.5 installation program?
Kacper
Message 4 of 15
(4,355 Views)
Kacper
YES! It is possible to install & have LV 7.1 & 8.5 up & running in the same computer, if & only if...
1] LV 7.1 is installed first & then LV 8.5 is installed next.
2] Else, it wont allow you to install LV 7.1 since a higher version of LV is already present in your system.
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 15
(4,354 Views)
I think Traditional DAQ 8.5 may not be compatible with LV 7.1, but I m not sure...
Normally, when you install a device driver of higher version, it ll overwrite the lower version if already present.
It is better you contact you local NI guys about this information.
Message 6 of 15
(4,351 Views)
First, you install all the CDs related to LV 7.1 including the device driver CDs also. Then you do the complete installation of LV 8.5 with the set of all CDs that came with it. You should not be encountering any problem in both of your development environments & also while you distribute your application.
Message 7 of 15
(4,350 Views)
regarding NIDaq take a look here
 http://digital.ni.com/public.nsf/allkb/97D574BB1D1EEC918625708100596848
Message Edited by Coq rouge on 05-27-2009 10:53 AM
Message 8 of 15
(4,344 Views)
Where is the missing link?
Message 9 of 15
(4,338 Views)
Sorry, my browser problem... Smiley Sad
Message 10 of 15
(4,335 Views)
