LV 7.1 and fpga module 1.0
i upgraded to LV 7.1 and...my FPGA module 1.0 doesn't work anymore! should i have an upgrade of the FPGA module? if so, why this was not documented? URGENT ISSUE DEVELOPMENT is STOPPED.
(4,014 Views)
I don't know for sure if FPGA 1.0 supports 7.1 or not, NI will have to answer that. FPGA 1.1 was released at teh saem time as 7.1, so it may be needed.
I would try uninstalling FPGA, then reinstall it into LabVIEW 7.1 directory. I don't know what steps you did when you installed 7.1, but if you all you did was install 7.1 and leave 7.0 installed, FPGA will not automatically be available in 7.1, it will stay in 7.0.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(4,014 Views)
Ed is right. LabVIEW FPGA 1.0 cannot work with LabVIEW 7.1. you will need to use LabVIEW FPGA 1.1 with LabVIEW 7.1. This is the case for all LabVIEW Add-on Modules where you cannot use a previous version of the Add-on Module with the latest LabVIEW.
I hope that this helps,
Mike
(4,014 Views)
Hello, i confirm your comments: LV 7.1 requires indeed FPGA module 1.1. The NI support has sent us immediately the 1.1 module and we are up and running again. The same is true for IMAQ (1.5.1) and for the RT module.
Thanks to everybody
Piero
(4,014 Views)
hi,
i need fpga module 1.0 for my application.. im using labview  7.0.... where could i find the toolkit for fpga module 1.0
guide me to clear my doubt..........
N. Srinivasan
(2,887 Views)
