LV 7 Vision
is there anyone out there successfully implemented a LV program with embedded images on the front panel? is it possible to draw a line and detect the edges in the image?
thanks
(2,636 Views)
solid;
You can do line profiling with IMAQ from NI, or with IVision from HYtek Automation.
You can use the picture indicator to show images in a LV front panel.
Regards;
Enrique
www.visecurity.com
www.vartortech.com
(2,636 Views)
