LV 8.2 Generic file I/O error
Nope, I am using 8.5 over a local network and it fails around 15 - 20 times on saves.
Message 51 of 61
(2,313 Views)
My little finger tells me that an update (8.5.1 ?) should correct this in a matter of weeks.
Side note : when the file generic IO error occur, do a "save as", select "rename" and it works. Doing this avoid you to have to try to save 20 times 😉
I have no tip for when you save multiple VIs... Smiley Sad
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 52 of 61
(2,309 Views)
Hi pgaastra,
You would need to have LabVIEW 8.2.1 to be able to apply the patch. If the issue is causing too much trouble, I would suggest you contact your NI Sales Reprentative at http://www.ni.com/contact/ for more information in obtaining LabVIEW 8.2.1.
Stanley Hu
Applications Engineering
http://www.ni.com/support
Message 53 of 61
(2,278 Views)
I got sick of the Generic file I/O error so I installed the patch you mention.  However the first time I tried to save a modified file I still have the dreaded Generic file I/O error.
Any special tricks on the patch install?
Message 54 of 61
(2,233 Views)
Hey pgaastra,
I'm sure you read the install file, but in case you didn't, its not like a normal install routine. You have to manually copy the files to appropriate directories after they are unzipped in the temporary directory.
Its all in the readme_LV821f4.txt file that unpacked with the download.
Maybe you did that and are having trouble anyway, in which case, someone else will have to step in here, I haven't had any problems sine intalling the patch.
Paul Johnson
Renco Encoders, Inc
Goleta, CA
Message 55 of 61
(2,217 Views)
Oops.
I read the readme and did the mods to the labview.ini file but the lines to add had speech marks round them.  I put the speech marks into the ini file.  I've taken them out and so far so good, it saves OK.
Message 56 of 61
(2,204 Views)
Anyone heard anything on this issue?
Its kinda dragging on a little is it not?
What about the open NI Job, did it never get resolved?
Message 57 of 61
(2,085 Views)
I've never installed 8.5, so I don't know if they patched that yet or not. Is that what you are referring to? I'm not sure there was ever an open ticket on this problem in 8.5. Looking back over the thread, I see you are irrevocably running 8.5.
Last I heard this was still a bug on 8.5., no patches. Seems kind of lame. I'm definitely holding off on installing 8.5.
http://zone.ni.com/devzone/cda/tut/p/id/6449#42G7H7O5%20by%20Category
Paul Johnson
Renco Encoders, Inc
Goleta, CA
Message 58 of 61
(2,064 Views)
I vaguely remember a ticket being rasied for 8.5.......but it could have been 8.2.
Its a a wee bitty to late for us as we are already running 8.5 & as far as I am aware there is no turning back!
Usually when an update for a product comes to market I install it straight away, I have the feeling I will be holding off in the future Smiley Sad
Just want to be able to save without multiple attempts and have faith that what I have done hase saved.
Message 59 of 61
(2,046 Views)
LabVIEW V 8.5.1 is available for download and in the bug fix list I see under Miscellaneous:
42G7H7O5  File I/O error: cannot save NameOfVI.vi
No mention of "Generic" but from previous postings to this thread I see the CAR? number 42G7H705 is the number relating to this thread.  So it looks like it is solved.
P.S. I was wondering why not many people were worried about this bug.  I have been reading a few post to the LabVIEW list and see that many people seem to have problems with their IT departments.  One solution someone had was that they were allowed LabVIEW if their computer was not connected to the network.  Maybe the majority of LabVIEW users store all their stuff on their local hard drive.
Message 60 of 61
(2,007 Views)
