LV 8.5.X: Converting String Data/Time to Timestamp
Hello again,
is there really no convenient way to convert a String Data/Time to an
Timestamp?
Thanks and greetings
Udo
(2,522 Views)
You can use the Scan from String function:
Look at the bottom for an example. If you can't get the format string right, you can configure a timestamp control/indicator to what you need and then use the properties (right click) then select Advanced at the bottom to get the string you need.
(2,507 Views)
