Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
LV 8.5.X: Converting String Data/Time to Timestamp
Udo
Member
06-10-2008
12:40 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hello again,
is there really no convenient way to convert a String Data/Time to an
Timestamp?
Thanks and greetings
Udo
0
Kudos
Message
1
of 2
(2,664 Views)
Reply
Re: LV 8.5.X: Converting String Data/Time to Timestamp
PhillipBrooks
Active Participant
06-10-2008
01:24 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can use the
Scan from String
function:
Look at the bottom for an example. If you can't get the format string right, you can configure a timestamp control/indicator to what you need and then use the properties (right click) then select Advanced at the bottom to get the string you need.
LV Punk: Global free, sequence structure free and
BETTER THAN YOU
Coordinated Universal Time (UTC) format string:
%^<%Y-%m-%dT%H:%M:%S%3uZ>T
1
Kudo
Message
2
of 2
(2,649 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
