LV 8 PDA doesn't compile any more
Dear LV 8 PDA users,
I have a VI with some sub VIs containing some clusters with arrays
and array lusters.
Until last saturday everything works fine. Today I have tried to add some
more code and now it takes more than a quater of an hour and LV does
several million file accesses (seen with filemon) and after all it does nerly
nothing and the taskmanager shows 100% load and the processs causing
this load is the CLARM.EXE or with other words the ARM C-compiler.
The Project isn't realy big it seams that there is a Problems with complex
clusters.
Any ideas?
With kind regards
Martin Kunze
KDI Digital Instrumentation.com
e-mail: martin.kunze@digital-instrumentation.com
Tel: +49 (0)441 9490852
(2,528 Views)
Hi TheProf,
Why not try and make your cluster simple(not complex).Maybe that is the problem...we had some issues with PDA module.
Have you tried to upgrade from 8.0 to 8.0.1 PDA module?? The latter took care of some bugs.
Hope you find this helpfull,Good luck.
Ohiofudu
CLAD
Certified LabVIEW Architect
Certified TestStand Architect
(2,513 Views)
