I got this Testfile,
you can see attached file.
and I wondered if I can set cursors in a graph, for each testname from the file, after the time stamp?
more explained, I need to plot the data on a graph with the timestamps (no problem ) and I also need to plot cursors (in the right x-time position) for every testname in the file.
I must make it work, so I just need to know if it is possible.
HFZ
