dynamic change of ring elements
I am wondering if there is a method exist to update ring elements dynamicaly during the vi is running...???
Example:  I have a TCP listen VI that get IP address from different TCP client as they are connecting to the server and I want the user could select one of these client vs the IP address in the ring control to execute any test with it...
Thanks in advance for advices
HaemoPhil
(2,762 Views)
Hello HaemoPhil,
use the property node "strings and values" to change the appereance of your ring at runtime!
(2,758 Views)
