data exchange between loops in different vi's
hello,
in the top level vi of my application i've got a daq.
data from the daq is needed in a low level vi.
both vi's are controled with queues.
the problem is that i solve the data exchange with a global variable.
i there any other solution to avoid global variables.
markus
(2,739 Views)
You can also exchange the data with queues. Since version 6.1 or 7.0 you can define a queue to handle any datatype. I have a command queue and a response queue for each pair of independent VIs which must exchange data, commands, or status. The command queue often passes a cluster with and enum (the command) and a string or numeric with parameters. The datatype of the response queue depends on what needs to be returned. Sometimes it is a clsuter with a status enum and a data variable. Works fine. No globals.
Lynn
(2,731 Views)
If you have LabVIEW 8.0, you could use the new "Shared variable" 🙂
(2,725 Views)
here
http://forums.ni.com/ni/board/message?board.id=170&message.id=163697
we come up with multiple ways Smiley Happy
Hey, has this already been noted for the FAQ?
Greetings from Germany
Henrik
LV since v3.1
(2,708 Views)
@WeberM wrote:
hello,
Another hint: If your daq is somehow timecritical it is always a good solution to not run it in the top level vi IF your toplevel vi also has the GUI . More about threats and the UI threat  in the KB.
Henrik
LV since v3.1
(2,702 Views)
