Is it possible,from file values ,to set the position of cursors In a graph
I got this Testfile,
you can see attached file.
and I wondered if I can set  cursors in a graph, for each testname from the file, after the time stamp?
more explained, I need to plot the data on a graph with the timestamps (no problem ) and I also need to plot cursors (in the right x-time position) for every testname in the file.
I must make it work, so I just need to know if it is possible.
HFZ
(2,387 Views)
If I do not overlook something I'd say it is possibel.
I know that you can add as many cursors to any graph as you want. AND you can position these to whereever you want.
I'd suggest binding the cursors to a plot and than position it to the apropriate point.
Greetings from Germany!
Uwe
(2,384 Views)
I made it, So therefore i think i'll attache it in here so other can make use of it!!!!
I Looove labview !!!
Regards
Zamzam
HFZ
(2,377 Views)
