LV Database Toolikit Error -2147217865
Hello.
Curetly I'm trying to familiarize myself with LV Database Toolkit version 2014.
In our company we are using database on remote server, so our IT guy installed on my computer Oracle and sets DSN. Now, in LV, I'm able to create connection and list all tables in that database, but when I try to list column information I'm getting this error:
"Error -2147217865 occurred at NI_Database_API.lvlib:Conn Execute.vi->NI_Database_API.lvlib:DB Tools List Columns.vi->Untitled 1"
In possible reasons it says that table doesn't exist on database, but that is non-sens. is there something that I'm missing? Something in DSN setting or....?
Bellow is screenshot of my code and that error message.
(4,767 Views)
Accepted by SefaraP
Error:ORA-00942: table or view does not exist
You tried to execute a SQL statement that references a table or view that either does not exist, that you do not have access to, or that belongs to another schema and you didn't reference the table by the schema name.
The option(s) to resolve this Oracle error are:
Option #1
If this error occurred because the table or view does not exist, you will need to create the table or view.You can check to see if the table exists in Oracle by executing the following SQL statement:
SELECT *
FROM all_objects
WHERE object_type IN ('TABLE','VIEW')
AND object_name = 'OBJECT_NAME';
For example, if you are looking for a suppliers table, you would execute:
SELECT *
FROM all_objects
AND object_name = 'SUPPLIERS';
Option #2
If this error occurred because you do not have access to the table or view, you will need to have the owner of the table/view, or a DBA grant you the appropriate privileges to this object.
Option #3
If this error occurred because the table/view belongs to another schema and you didn't reference the table by the schema name, you will need to rewrite your SQL to include the schema name.
For example, you may have executed the following SQL statement:
SELECT *
FROM suppliers;
But the suppliers table is not owned by you, but rather, it is owned by a schema called app, you could fix your SQL as follows:
SELECT *
FROM app.suppliers;
If you do not know what schema the suppliers table/view belongs to, you can execute the following SQL to find out:
SELECT owner
FROM all_objects
This will return the schema name who owns the suppliers table.
Source: https://www.techonthenet.com/oracle/errors/ora00942.php
uday
(4,736 Views)
Hello @udka
Thank you for your answer, you were right about this. The problem was in calling table without proper schema name. Now everything seems to work correct.
Best regards
(4,711 Views)
SELECT *
FROM suppliers;
SELECT *
FROM app.suppliers;
SELECT owner
FROM all_objects
(3,819 Views)
