LV OOP - Plugin
I have another question about ppl. I have developed three plugins with different subvis and gui elements. How can I make a ppl to call dynamically a plugin gui at runtime. How can I implement the object? Master class shell be named drivers from which the three classes inherits (nws, opc, sve) - every class has many different subvis where no data are the same. Would it be better to make it without the oop? Is it possible to load subvis from lvlibp files without using classes?
Best Regards,
Joachim
Message 11 of 11
(413 Views)
