LV accesses uninstalled PushOK
I have uninstalled PushOK, but LV2010 still looks for it. How do I reset the SCC to none. The LV SCC menu is grayed out as when no SCC is installed yet at startup I get the pop-up message below.
(2,550 Views)
Did you do what the dialog says: "Select Tools >> Options to reconfigure source control"?
If you did and you still get it, then open the LabVIEW.ini file (in the same folder as the exe) and remove all lines related to SCC.
(2,541 Views)
Removed the SCC ini lines and they're put back by LV when opening LV2010.
The following lines persist.
SCCConfigData=""
SCCProviderName="PushOk SVNSCC"
SCCProviderLocation=""
I guess I should have removed the SCC first from LV then uninstall PushOK. Maybe I'll try to reinstall PushOK just for that purpose...
(2,525 Views)
Pop up no longer shows after putting PushOK back, then LV no longer grayes SCC config. Then I configured LV to use "none" for SCC. A fifo install problem.
(2,524 Views)
