LV12 Compiler Error
Interesting event while duplicating a simple class, the World did not end when I clicked the button although I was bracing (I swallowed my coffee and put down the cup).
consider it reported to tech support.
(2,644 Views)
Hi Darin.K,
This behavior is usually due to either a dependency or a path change in the application when a VI is moved to a different location but could be related to a number of other issues that can be difficult to troubleshoot. A recompile of the VI hierarchy or a Mass Compile generally fixes these issues.
David C
(2,597 Views)
