Labview error: no longer builds executables
I have full development license and my labview creates an error when i try to build executables.  does this error mean anything to anyone?  btw, it used to make .exe's without issue.
the error reads:
Error 7 occurred at AB_Build.lvclass:Create_Destinations.vi -> AB_Application.lvclass:Create_Destinations.vi
when i try another time the error reads:
Error 7 occurred at Copy in AB_Targetfile.lvclass:PostBuild.vi->AB_Application.lvclass:PostBuild.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Create_Build_Application.vi->EBUIP_Global_OnCommand.vi->EBUIP_Global_OnCommand.vi.ProxyCaller
thanks,
Erik
(2,577 Views)
Hi Erik,
A couple of questions for you - What is your destination directory for the build? Do you have write permissions for that folder? Is it on a network drive?
Does this happen for all exes or just for this specific project? If you build a simple VI into an exe on the desktop, do you get the same error?
What version of LabVIEW are you using?
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments | Certified LabVIEW Architect
(2,548 Views)
