08-04-2009 04:11 PM
I just upgraded a 64bit Vista machine to LV2009.
I then went to install the LV2009 Real Time Module and it said I needed to install the LV2009 32 bit version first.
Do I need to intall both the 64bit and 32bit versions on the same 64bit Vista machine before install LV2009RT?
08-05-2009 04:02 AM
Hey,
LabVIEW RT only works with the 32bit LV, that's the reason why it asks for it.
Christian
08-05-2009 10:40 AM
Well that is certainly unfortunate.
Any idea if Labview RT and Labview 2009 32 bit will run properly on an x64 machine as x86 executables?
08-05-2009 04:40 PM
