LV2009RT and 64bit LV2009
I just upgraded a 64bit Vista machine to LV2009.
I then went to install the LV2009 Real Time Module and it said I needed to install the LV2009 32 bit version first.
Do I need to intall both the 64bit and 32bit  versions on the same 64bit Vista machine before install LV2009RT?
Rick Foster
MIT Kavli Institute for Astrophysics and Space Research
(3,007 Views)
Hey,
LabVIEW RT only works with the 32bit LV, that's the reason why it asks for it.
Christian
(2,974 Views)
Well that is certainly unfortunate.
Any idea if Labview RT and Labview 2009 32 bit will run properly on an x64 machine as x86 executables?
Rick Foster
(2,956 Views)
LabVIEW 2009 32-bit will run fine on Vista x64, as will the executables.
Jeff | LabVIEW Software Engineer
(2,935 Views)
