LV2012 runtime .msi file
We are building installation of our application.. Can you suggest where I can find .msi file for Labview Runtime 2012
Leela
(4,053 Views)
When you include additional installers in an installation build specification it requests the installation files from the location that they were installed onto your computer. This is typically the Developer Suite DVDs but also could be from the NI Update Service or a manual download from ni.com.
You can also manually download whichever runtime engine you need from here: http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du/q/LabVIEW%202012%2...
And run the install, which should update the system's pathing to where it assumes the MSI is.
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(4,048 Views)
I followed the links, and I see a link to an executable, but not to an msi file.  I have downloaded the 2017 run-times, and they contain a self-extracting executable but not an msi file. Are there any releases of the LabVIEW Run-Time that are the msi file that one can use to do a silent install without any popups coming up - for an unattended installation?
thanks,
(3,726 Views)
The following links will be helpful in doing a silent installation:
Customize and Automate Installation of a Single Installer
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Ld6SAE
How to Do a Silent Installation of National Instruments Installers
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAE4SAO
Create Silent Installer for LabVIEW Executable and LabVIEW Run-Time
Enginehttps://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAfySAG
Best,
Misbah
(3,717 Views)
