sbRIO 9607 Ping Problem
I am working with sbRIO 9607 and I am using a gateway. I want to build a web-server application. Hence I need this gateway. However, if I connect this gateway to ethernet port of sbRIO, and ping to www.google.com, it takes the IP of google, but all response bits are lost. However, If I connect the gateway directly to my computer, I can ping to www.google.com, so gateway works correctly.
As I understand, sbRIO firewall does not give permission me to connect to internet. I have checked the firewall document in init folder by using ssh, however there was no such a restriction or a rule.
How can I ping to a website correctly by using sbRIO ssh?
Thanks.
(3,200 Views)
Hi onrep,
Do you currently have the RIO connected to a wireless network?
Connecting a Real-Time Target to a Wireless Network
Are you able to ping other devices on the network?
Alex
Hardware Engineer
(3,173 Views)
