Vision Development Module
Should be a quick question...
Does Vision Acquisition Software (VAS) come with the Vision Development Module (VDM)?
I am trying to use NI-Imaq and the program gets upset that VAS isn't activated, which is correct when I check the license manager, but I need to know if I VAS is supposed to be included with the VDM package, which I do have licensed.
(3,184 Views)
All the answers : https://www.ni.com/en/support/documentation/supplemental/18/licensing-national-instruments-vision-so...
So you should be able to activate VAS with your VDM licence. Or at least you should have a licence somewhere.
CLAMaxime -- Kudos are a great way to say thank you
(3,173 Views)
Note that if you have a licenced VDM, then your license also includes a RunTime License for the VAS on the same computer that has the VDM.  In particular, if you develop a Vision application on your machine, but want to run it on another machine, you need a VAS license for that other machine.  [We fell into this situation once ...].  Note that this is consistent with the excellent Summary that Maxime posted.
Bob Schor
(3,149 Views)
