LV2013 hangs on Resolve Load Conflict Dialog
Thanks for the tips and updates on this.
I tried mass compiling as was suggested but I was again able to reproduce the issue as I have described it in the first post. (Report ID: f6783551-a533-4d1e-982b-845a9fabea9f )
Then I tried uninstalling the VSI TSVN toolkit and I couldn't get it to crash again.
Next I reinstalled the toolkit and mass compiled as suggested => no crash. Hope it stays like that also 🙂
Thanks again and keep up the good work guys!
-Matti
Message 21 of 39
(2,246 Views)
FYI: I've been seeing this randomly for some time. I do have the Tortoise SVN toolkit installed but believe I have seen this before adding it.  When it occurs, the mxlvgetfilepathbatch.vi dialog continues to increment the "Loaded" count but otherwise things are just hanging
Message 22 of 39
(2,229 Views)
Whoops they did it again
I'll try a MC There
Message 23 of 39
(2,207 Views)
Steps to reproduce:
  • Have a project open
  • Realize "Hey I need a pausable resetable timer for this vi" (I Just linked to one on the community this week so go here)
  • I know I'll need the enum type def so download that first and save as (sub copy for original)
  • Download Timer2.vi.... write up the report for Jeff P
Message 24 of 39
(2,194 Views)
Hello everyone,
An update on this issue - we have been working with Viewpoint and version 1.8 of the TSVN toolkit will be released shortly through VIPM to fix this. If you still experience this issue after installing 1.8, please post back to this thread.
Thanks for your help and happy new year!
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
Message 25 of 39
(2,166 Views)
Further update:
2 new versions of TSVN Toolkit are available on the LabVIEW Tools Network in VI Package manager and both SHOULD resolve this issue. Version 1.7.1.65 resolves the issue and supports TSVN 1.7.x only.  1.8.0.1 also resolves the issue and supports TSVN 1.8.x only (1.8 was previously unsupported).  You can download both from VIPM or here and then choose the appropriate version of the package in VIPM (see below)
Message 26 of 39
(2,145 Views)
I have VSI TSVN Toolkit v1.8.0.1 and saw the mxLvGetFilePathBatch.vi dialog pop up and same problem - ie. the labview dialog showing the conflicts pops up just prior and the two dialogs "lock each other out".  Only difference seems that the mxLvGetFilePathBatch.vi is not modal to the project window so I was able to close the project before force closing the mxLvGetFilePathBatch.vi dialog with task manager.  I left it overnight prior to doing so.
Message 27 of 39
(2,119 Views)
I found this thread today. I checked and had the 1.8.0 version of the toolkit. Updating it now.  Hopefully this problem goes away, if not I will just leave the toolkit uninstalled for now.
QFang
CLD LabVIEW 7.1 to 2016
Message 28 of 39
(2,101 Views)
nope. still crashes.
I have a project folder where I was re-organizing some files in preparation for building a pacakge (using package manager). In the process one example/test vi needs to be re-linked to the lvclass and I get the "Resolve Load Conflict" dialogue behind the "mxLvGetFilePathBatch.vi" dialogue which offers "stop..." as the only valid choice and it of course does not work.
I'll be removing the toolkit for now.
Toolkit was the 1.8....1 version (latest)
I have TortoiseSVN version ::
TortoiseSVN 1.8.4, Build 24972 - 64 Bit , 2013/11/24 11:15:39
Subversion 1.8.5, -release
2013 fully updated, and less than 2 week old clean install of windows/labview/everything.
QFang
Message 29 of 39
(2,098 Views)
Just as an update, I have been actively working to solve this problem, and I think I have a solution, but it has required refactoring a large amount of code. I hope to have a new version of the toolkit out in the next week or so that will hopefully solve this issue once and for all. Thanks for your patience.
In the mean time, I would be happy to answer any other questions about the TSVN Toolkit.
Eric
Message 30 of 39
(2,056 Views)
