LV2018 SP1 : Change language of LabVIEW
On my computer, I need to change language of LabVIEW to English.
I saw this old post for LabVIEW 2010.
https://forums.ni.com/t5/LabVIEW/change-LabVIEW-language/m-p/1886287#M636615
Is it same method since 2010 ?
So, uninstall and reinstall ?
No option to force install products and avoid error message : ' You have a different language edition of LabVIEW.... You must uninstall that edition before you can install the English edition.'
(3,508 Views)
Hi Mini,
you can have different "flavours" of LabVIEW installed in parallel (32bit vs. 64bit) or different years in parallel (2017 vs 2018).
But to change the language of your installed version you need to uninstall the current version and install the English version instead…
(3,499 Views)
Yes, I have 2015sp1 / 2016 / 2017sp1 / 2018sp1.
All in French.
So, I will uninstall 2018sp1 Fr. I wish, it's enough to install 2018sp1 English after.
If I need to uninstall all, it will be crazy bad !
(3,496 Views)
Accepted by Minikisscool
Hi Mini,
well, I had some years with a German LabVIEW version, but the last years I went for the English version. Much easier programming…
(3,481 Views)
it's done, I uninstall 2018sp1 Fr to install same version in English.
All work fine
(3,435 Views)
