LV2020 NXG code conversion with CLI to SLI
Dear Community
I start to use NXG 5 more frequently and want to convert some libraries written in LV2020 to NXG5 using the code convertion tool.
I have already converted some *.vis including CLFNs (call library function nodes) sucessfully to NXG5. In these cases the converter created a very good *.SLI file with all the calls.
Now I tried to convert a library with no success. The result is an empty project with no converted files.
Is there a specific trick to solve this problem ?
Where must the used DLL be located that it works ?
Is the header file neccessary for proper conversion ?
Is the conversion of a library a save way to convert ?
Thank you for your input
Gernot Hanel
IONICON Analytik Gesellschaft m.b.H.
(1,593 Views)
Accepted by topic author nottilie
I have pointed out the problem.
LV NXG is not able to handle the EXT datatype.
When having a VI with the EXT datatype to convert all the conversion fails without any error message.
@NI Please add this to a kind of BUGLIST because it is very hard to find out which vi is responsible for the error as no error is stated
Thank you
Gernot Hanel
(1,568 Views)
