LV5.01 & WIn98: size of harddisk?
Hi !
I would like to have the information how much space is left on my
harddisk with the volume info.vi.
Now, using a 4 gb disk I get a disk size of 2gb and since I haven't
used up less than half of my disk space yet all of it is reported
to be unused.
any solution to that?
Christoph
(2,649 Views)
Christoph Klein wrote:
> Hi !
> to be unused.
> Christoph
Christoph,
Some of the disk size utility VI's that have been made available at
times in the past had limits on the hard disk size for which they
worked. I had a version from NI at one time that worked up to 2GB. I
think I got an update at one point that worked up to 4GB. My guess is
that you are using the former.
Dave Thomson
David Thomson 303
-499-1973 (voice and fax)
Original Code Consulting original.code@technologist.com
National Instruments Alliance Program Member
Research Scientist 303-497-3470 (voice)
NOAA Aeronomy Laboratory 303-497-5373 (fax)
Boulder, Colorado dthomson@al.noaa.gov
(2,649 Views)
