Christoph Klein wrote:
> Hi !
> I would like to have the information how much space is left on my
> harddisk with the volume info.vi.
> Now, using a 4 gb disk I get a disk size of 2gb and since I haven't
> used up less than half of my disk space yet all of it is reported
> to be unused.
> any solution to that?
> Christoph
Christoph,
   Some of the disk size utility VI's that have been made available at
times in the past had limits on the hard disk size for which they
worked.  I had a version from NI at one time that worked up to 2GB.  I
think I got an update at one point that worked up to 4GB.  My guess is
that you are using the former.
   Dave Thomson
David Thomson                   303
-499-1973 (voice and fax)
Original Code Consulting        original.code@technologist.com
   National Instruments Alliance Program Member
Research Scientist                       303-497-3470 (voice)
NOAA Aeronomy Laboratory                 303-497-5373 (fax)
Boulder, Colorado                        dthomson@al.noaa.gov
