LV5: pause hot key
I'm searching for a hotkey to pause a lab-view-program, I have to write a macro to steer the LabView. Does someone know the combo. I searched the help and tried some out, but the only success was an inoperable menu 😞
My first language is German, please ignore my faults...
(2,754 Views)
Hello Hardware_...,
in the block diagram window you will find a pause button - but thats only useful for debugging 🙂
If you need this in runtime (or executable) you will have to program this on your own:
- check if the user presses your "hotkey" (boolean button or whatever)
- set a global variable to "pause mode"
- check this global in all subvis and react on it...
When you use a state machine you can easily stop after each state (just go to state "pause mode")...
(2,748 Views)
Hello GerdW
Thanks for the answer. It's what i feared 😞 For my program it's a bad thing... I will have to solve it in some kind of endless loops everywhere the program stays longer time.
Greetings
Hardware_Tester
Message Edited by Hardware_Tester on 04-12-2006 03:43 PM
(2,744 Views)
