LV5: setting bit on parallel port
Hello
I tryed to set a single bit on the parallel Port, but it did not work. What I did:
  • Added the line serialDevices="COM1; COM2; COM3; COM4; COM5; COM6; COM7; COM8; COM9; LPT1; LPT2; LPT3; LPT4;" to C:\Program Files\National Instruments\LabVIEW\labview.ini as proposed here
  • soldered the pins 11+12 to GND 24 for setting the port in a normal state
  • used Pin 18 + 2 as signal D0
  • set the LPT in BIOS to Bidirectional (Unidirectional is not settable)
  • used the serial funktions with Port 10 --> Error 37
  • used the example script --> Nothing happens, even portmon does not log anything
Now i'm quite frustrated, if it doesn't work until tomorrow i'm totally stuck Smiley Sad
My first language is German, please ignore my faults...
(2,429 Views)
-- [ Added the line serialDevices="COM1; COM2; COM3; COM4; COM5; COM6; COM7; COM8; COM9; LPT1; LPT2; LPT3; LPT4;" ]
The line is incorrectly formatted. The last semicolon (after LPT4) shouldn't be there... On the end you only write the double quotation mark.
Good luck and best regards
Swiss Support Team
(2,397 Views)
