Hello
I tryed to set a single bit on the parallel Port, but it did not work. What I did:
- Added the line serialDevices="COM1; COM2; COM3; COM4; COM5; COM6; COM7; COM8; COM9; LPT1; LPT2; LPT3; LPT4;" to C:\Program Files\National Instruments\LabVIEW\labview.ini as proposed here
- soldered the pins 11+12 to GND 24 for setting the port in a normal state
- used Pin 18 + 2 as signal D0
- set the LPT in BIOS to Bidirectional (Unidirectional is not settable)
- used the serial funktions with Port 10 --> Error 37
- used the example script --> Nothing happens, even portmon does not log anything
Now i'm quite frustrated, if it doesn't work until tomorrow i'm totally stuck
My first language is German, please ignore my faults...
