LV6.1 How to set multicolors in a register control
Dear All,
I would like to change the color of a single page of a register control.
I found the property multcolor.
As long as it is set to false I can change the color of the hole register control.
But how do I change the property for the color of a single page,
if I set the property multcolor to true?
How do I address a single page of the register control?
Thanks for your help
SL Willi Wipp
A short reply would be nice.
SL Willi Wipp
Message 1 of 15
(4,197 Views)
What is a register control Smiley Surprised ?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 15
(4,193 Views)
Hi TiTou,
thanks for your reply.
As I use the german version I maybe used the wrong synonym
, sorry.
Could it be tab control?
Message Edited by Willi Wipp on 10-05-2006 07:46 AM
SL Willi Wipp
Message 3 of 15
(4,192 Views)
Indeed, tab control is the anme in english 😉
look at the exemple attached 😉
Message Edité par TiTou le 10-05-2006 02:56 PM
Epictetus
Antoine Chalons
Message 4 of 15
(4,185 Views)
Hi TiTou,
thanks for your again very fast reply.
Could it be that the example opens only in LabVIEW 8.2?
Than it can take some time until I respond, as I have to install 8.2 first. 😉
In the moment the highest version that I have installed is 8.0
and with this version I can not open it.
SL Willi Wipp
Message 5 of 15
(4,177 Views)
there it is in LV 8.0 😉
Message Edité par TiTou le 10-05-2006 03:05 PM
Epictetus
Antoine Chalons
Message 6 of 15
(4,177 Views)
Hi TiTou,
thanks again for your fast reply.
The example did work perfect. So my problem is solved.
For all then others, see the attached LabVIEW6.1 example
Thanks and have a nice day
Message Edited by Willi Wipp on 10-05-2006 09:13 AM
SL Willi Wipp
Message 7 of 15
(4,163 Views)
Warning for for LV 6.1 users of this example.
I BELIEVE (not sure on version number  Smiley Sad ) LV 6.1 had a bug where attempts to set the color of a non-visable page of a tab control would crash LV. Smiley Surprised
Work-around was to check the visability of the page and conditionally write the color only if "visable = true".  Smiley Wink
Ben
Message 8 of 15
(4,151 Views)
Good to know Smiley Surprised !
Thanks for giving the info !!!
Message Edité par TiTou le 10-05-2006 04:44 PM
Epictetus
Antoine Chalons
Message 9 of 15
(4,144 Views)
Also, for LV6.1 users, those Page refnums should be closed to avoid the old memory leak problem if this code is going to be run repeatedly (e.g. in a loop of some kind).
Fading out. " ... J. Arthur Rank on gong."
Message 10 of 15
(4,127 Views)
