LV7.1 Troubles to get a "Region of Interest" with the "get last event" method
Hello !
When using the "get last event" method on a displayed image, I can't get a ROI input : the method never returns a type=2 and doesn't draw the rectangle on the image.
Moreover, I experience a behaviour I don't quite understand with the command array for the "which event" parameter : the left hand value is a digit, and switches the right hand value from "no event"  to "draw event" and son on,.. but I can't understand what the left hand digit is exactly used for.
I want the method to let me draw a ROI and returns the coordinates, just like the "extract example.vi" - that came in the VISION application - does .
Many thanks in advance for any help
Thierry
(2,594 Views)
Hello Thierry,
I done something you are looking for times ago. I'll give it to you in attachement of this email. In this application you can select a ROI as you want.
Enjoy,
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(2,569 Views)
