I have had another change to look at the second VI which produces
incorrect results. Looks like the corruption that causes LabVIEW to
crash in the first VI posted to this thread does some wicked things to
the for loop instead of causing a crash.
I ran the VI with hi-lite execution and noticed that the for loop only
executes once, so that explains why only the first page of the result
array is correct, and the "correct array" matches the first page of the
erroneous array rather than the last page (the array should only pass
out the last value). I passed this information along to R&D. I did
not create a new CAR because these issues (crash and incorrect results)
are tied to the same root cause.
Cheers,
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
