LV8.5.1 Labview memory is full error message Windows Vista 64bit
I have a small application where the top level vi will no longer load into either LV8.5.1 or LV8.6 (see attachment) when using the project exployer.  Anyone else have this problem?
Hardware:
ASUS G1 4Gig memory
Windows Vista 64bit
Karl
(3,117 Views)
Beach,
Can you include the VI as an attachment.  I would like to see if I can open it.
Jon S.
LabVIEW NXG Product Owner
(3,088 Views)
Hi Jon,
Here is the code,
Kal
(3,083 Views)
Hello Beach,
I received the same error when I tried to open your file.  What did you do before this error occured.  Did you save for a previous version?  Do you have a backup of this file?
Jon S.
(3,063 Views)
Hi Jon,
Yes, I did save for a previous version.  I have a backup but it is at a older revision level.
Karl
(3,055 Views)
Beach,
Can you post the previous revision.  I would like to see if I can produce the same error when saving for a previous version.  I would advise you to continue development from the previous revision and keep a couple of backups.  This bug was reported as fixed when LabVIEW 8.6 released.  If you encounter the error again can you post the VI that will cause the error when saved for a previous version.
Jon S.
(3,050 Views)
