09-18-2007 10:26 PM
09-18-2007 10:45 PM - edited 09-18-2007 10:45 PM
Do you want to install Visual Studio, CVI, etc.? It looks like you are running the device drivers DVD, and must have told it to install All device drivers, rather than just the ones it determined you needed when it scanned your system. So when it tries to install the device drivers for VS and CVI et al, it can't find that software on your PC. If you want that software, they would be on other CD's in your Developer's suite package. Install that, then run the Device Drivers DVD again.
If you only want to install Labview, rerun your DVD for your device drivers again, and only install the features that it wants. I find the device drivers DVD takes a long time to initialize, and I believe that is because it is scanning your PC to detect what other National Instrument products you have installed so it can populate the list of what drivers you need to install.
Message Edited by Ravens Fan on 09-18-2007 11:46 PM
09-18-2007 10:51 PM
09-18-2007 11:57 PM - edited 09-18-2007 11:57 PM
Message Edited by Matwelli on 09-18-2007 11:58 PM
09-19-2007 01:57 PM
