11-21-2005 09:11 AM
11-21-2005 09:36 AM
hi there,
i can't check if these vi's are those you are looking for cause my LV8-evaluation period expired, but please take a look at
LabVIEW 8.0\vi.lib\Utility\file.llb\*.*
i think these are the old file VIs. pls check if there is some kind of "classic" view for the functions palette for better access of these Vis.
11-21-2005 09:39 AM
Obviously you are very hot about this, and this thread is sure to start a few rants into a variety of things. Your example of the write to spreadsheet function should not be an issue, it still writes a tab delimted txt file that can be opened and read quite normally by notepad. I verified this to be sure. Granted the VI description does not give you this indication, but it works fine.
I have upgraded a number of concurrent projects to LV8 from 7.1.1 with few problems other than I am missing toolkits since I have not recieved my SSP upgrade for LV8 and probably jumped the gun. I certainly have not seen any issues that you have described like broken VIs, except where I have been doing some things 'under the hood' but nothing that took more than a few seconds to correct. I have been hesitant to re-install from previous versions and am working around this for a week or so until my promised SSP shows up.
Cheers and happy wireworks!
11-21-2005 09:53 AM
11-21-2005 02:41 PM
11-29-2005 03:01 PM
11-30-2005 02:56 PM
After reading the postings in this thread describing specific porting problems involving LV 8, I can think of one large application written in LV 6.1 that will be ported, if and when the time comes, to LV 7.1. We especially can't afford any weird GUI modifications, however minor; and we do a lot of file manipulation; and schedules are always too tight, so we have to minimize time to repair software, and time to regression-test on expensive contended-for hardware.
But our new applications will be built in LV 8. I expect the worst problems will be fixed soon enough, and we can find workarounds if we have to.
Yes, NI charges plenty, but LV is a great product and the world will have to keep current, by and large. Having said that, I hope NI doesn't morph into a Microsoft-like monopolistic money-sucking purveyor of mediocrity. I don't know whether or not to be optimistic on that point. These LV 8 glitches seem like "rush-to-market" issues, but maybe that's part of the problem. Related anecdote: at a recent free LV 8 seminar given by NI, I saw several demos crash or otherwise fail to work correctly.
The more market share NI has, and the more Microsoft-like features LV has (e.g. Projects etc.), and the bigger the headache for NI to keep backward-compatibility, the greater the incentive will be to charge more for tech support, issue skimpy documentation (NI documentation is OK but often patchy--Examples notwithstanding), and otherwise slide down the familiar slippery slope.
11-30-2005 03:18 PM
I can do nothing but assume that this is one of two things. Im guessing the latter choice B is correct.
A. This release was simply rushed to release. I have yet to find ANY USEFUL IMPROVEMENTS whatsoever.
B. The only reason LV8 was released was to make a multitude of minor changes, IN ORDER TO GENERATE SERVICE CONTRACTS.
As a matter of fact i have yet to discover a single worthwhile improvement. Not one. As a matter of fact i despise the fact that NI has decided to Re-Invent the wheel when it comes the SAVING!! Do i really need a 3 choice dialog box to save a file? Not only is this entire dialog totally un-needed, but the descriptions of the 3 choices are terrible. I literally had to read them several times in order to glean what the buttons really did. Im pretty sure we needed no improvement in "file saving" as this hasnt changed since windows v3.11.
There is no way NI did not forsee issues when they decided to change "write to file". I mean come on, when is the last time anyone wrote a vi that does not involve acessing a file?
11-30-2005 03:39 PM
Well, just last week I wrote a vi that has no file I/O. It controls the power of an industrial CO2 laser by adjusting duty cycle of a square wave. Yes, I do spend the $800 a year for the SSP for Professional Version. It is quite well worth if even if I only have used tech support twice in many years. Doing so has provided versions 6, 7, and now 8 for use in my company. Rapid development and deployment using LV has more than paid for itself many times over in productivity.
Just my angle on the 'extortion' situation.
11-30-2005 06:20 PM
