LV8 app doesn't find sub VIs on target machine
Hello
I had a running application, which I compiled and copied to a target PC.
Now I added some more features (subFile dlg, mergeErrors, Spline) and the built exe can't find the corresponding VIs when I copy the exe to the system it is supposed to run on.
The same VIs are used in a second app within the same project. No trouble - all VIs are found when I run that exe. I have checked all build params to be the same. When asked to locate the missing VIs, I point the RTE to the LV8/vi.lib/etc files. But it does not memorize the position - instead I have to run through the locating process again on new start.
What am I doing wrong - how can I teach LV to include the respective VIs in the app?
Thank you for your input.
Michael
(2,488 Views)
Hi Michael,
      Are the "new" VIs actually part of the hierarchy being compiled, or are they called dynamically?  If they are called dynamically (or part of a VI that's called dynamically) they need to be explicitly included in list of "Source Files" for the compile.  I only have 7.1 to look at now, it provides a "Add Dynamic VI" button - the concept is the same for 8.x.
Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(2,469 Views)
