LVCompare Tortoise Svn Bad Reports
In a nutshell "Reports do not contain any images!".
I have been wanting to generate reports from previous versions of vi's stored in my svn. I set up my TortoiseSVN according to the guide here:
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/configlvcomp_thirdparty/
The compare function works great.
However when i generate reports I expect the images to be displayed as well. and I end up with missing images in my xml file:
<funcChanges detailDesc="" diffType="objects added/deleted" imagePath1="" imagePath2="" objLabel="" objType=""/>
When i try to generate a word document i get Error 1617 and the file is never created.
I would really like not to have to screen shot each difference...
Any help on this would be great!
(3,032 Views)
I've only used LVCompare in a "hands-on" mode, doing the viewing myself and making notes (with pen and paper) on which versions were correct and why.  I never thought that this could be automated to save images ...
Bob Schor
(3,011 Views)
http://zone.ni.com/reference/en-XX/help/371361M-01/lvdialog/differences_dialog_box/
Shows the Create Report Button and references:
http://zone.ni.com/reference/en-XX/help/371361M-01/lvdialog/create_report_db/
The Webpage option states:
Report Type—Specifies the type of comparison report you want to create. You can select one of the following types:
  • Web Page—Creates a web page report. LabVIEW saves the report as a .xml document along with a folder that contains all screenshots (.png) and an XML stylesheet (.xsl). You can use the web browser on your machine to open the report.
Its in the documentation 🙂
(3,000 Views)
Did you ever solve the issue of missing images? I have the same issue.
(1,986 Views)
