LVDiff with VIs in library
I've successfully setup both LVDiff and LVMerge with TortoiseSVN and I'm using it heavily, but I get an error from LVDiff if the VI belongs to a library:
Error 1004 occurred at Open VI Reference in NI_procmphier.lvlib:CMP compare two VIs.vi->lvdiff.vi
Possible reason(s):  LabVIEW:  The VI is not in memory.
To load a VI into memory with the Open VI Reference function, a path must be wired for the VI Path input.
VI Name: TMCalc_Qp.vi
Has anyone changed LVdiff so that it works with VIs in library?
Message 1 of 17
(6,622 Views)
I just had the same problem, strange that no one has seen it before...
The correction is committed in the project's repository since 2 years, but the download archive contains an older version.
You can download the right version from this link. Just replace the vi in the lvdiff directory!
Charles
Message 2 of 17
(6,596 Views)
Ok, now it works excellent!
Thank you VERY much.
/LeifS
Message 3 of 17
(6,580 Views)
Hi, all.
Sounds like I need to get busy and release a new zipfile download.  Thanks for the reminder!
--Ian Dees
  LVDiff maintainer
Message 4 of 17
(6,562 Views)
Well, I'm glad I found this thread.  I downloaded the zip file last week and faced the same problem.  The new VI works....
Paul
Message 5 of 17
(6,516 Views)
I got an issue with lvdiff.
The lvdiff.ini file is missing in the archive !
Message 6 of 17
(5,059 Views)
Hello, Callahan.
The lvdiff.ini file gets created by lvdiff.exe so that lvdiff.vi knows what files to compare; we don't include it in the archive.
--Ian
Message 7 of 17
(5,038 Views)
I agree, normally the ini file is creatd by the run-time if it does'nt exist.
But not in this case, I don't understand why and how to solve my problem.
Message 8 of 17
(5,033 Views)
Hi, Callahan.
Does the problem persist if you install LVDiff to a different directory?  LVDiff was written in the days before the Program Files directory was protected, and (against good practice, I must admit) stores its .ini file alongside the .exe.  What it should do is at least use the application settings directory.  But installing to C:\LVDiff or somewhere similar may get around that restriction.
--Ian
Message 9 of 17
(5,030 Views)
I have set all autorisations on the meta-diff forlder, but maybe it's not enough.
I put it into c/program files.
I use Windows 7.
Any idea ?
Message 10 of 17
(5,027 Views)
