LabVIEW 11.0 This is the application template and cannot be run alone
Hello all,
                           After i complete building my executable & installer file, When i try to run my execuatable file then a message pops up stating - 'This is the application template and cannot be run alone'
After i try 4-5 times it runs or when i rebuild my project it works (Magically)?
Does anybody else encounter same problem ?
I already installed run time engine & following same procedure from last 2 years, Never found this problem before.
what is the reason for this & what is the solution ?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,407 Views)
I have the same issue. Sometimes the compiled exe works, sometimes I get the error message. No idea what makes the difference, though.
Using LV2011 SP1 on WinXP SP3 (32bit).
Sorry I can't be of more help, just wanted to let you know you're not alone Smiley Happy
(3,383 Views)
                            Will let you know if i got some solution. But what i found that this pose problem only if i run exe file. If i install & run then it wont pose problem.
--Ranjeet
(3,379 Views)
Good to know. I never created an installer if the exe file showed that problem, so I wasn't aware of this.
(3,377 Views)
Try this & then give me kudos if it works
--Ranjeet
(3,375 Views)
