01-28-2013 11:48 PM
Hello all,
After i complete building my executable & installer file, When i try to run my execuatable file then a message pops up stating - 'This is the application template and cannot be run alone'
After i try 4-5 times it runs or when i rebuild my project it works (Magically)?
Does anybody else encounter same problem ?
I already installed run time engine & following same procedure from last 2 years, Never found this problem before.
what is the reason for this & what is the solution ?
01-29-2013 05:02 AM
I have the same issue. Sometimes the compiled exe works, sometimes I get the error message. No idea what makes the difference, though.
Using LV2011 SP1 on WinXP SP3 (32bit).
Sorry I can't be of more help, just wanted to let you know you're not alone ![]()
01-29-2013 05:24 AM
Will let you know if i got some solution. But what i found that this pose problem only if i run exe file. If i install & run then it wont pose problem.
01-29-2013 05:54 AM
Good to know. I never created an installer if the exe file showed that problem, so I wasn't aware of this.
01-29-2013 06:07 AM - edited 01-29-2013 06:07 AM
Try this & then give me kudos if it works
