LabVIEW 17.0 Development system is not responding to windows
@NareshKumarLega wrote:
I am having admin privileges, ...
This still does not mean that LabVIEW has admin privileges, so please test if "run as administrator" makes a difference.
A missing labview.ini is not a problem, it will be automatically recreated with default settings.
However, if files are missing, maybe the entire installation is incomplete. Did you get any errors during installation? Did you reboot after installation?
Also scan your HD for errors and see if there are driver updates, e.g. video card. Scan the PC for malware.
Message 21 of 24
(1,412 Views)
My problem is solved after uninstalling antivirus from my PC
Message 22 of 24
(1,400 Views)
You should mark your latest post as the solution.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 23 of 24
(1,393 Views)
We had other cases in the forum where certain antivirus software had negative impact and it would be great if you could tell us what antivirus software you were using. This will help others in the same situation. (e.g. avast caused problems in the past)
If this was legitimate AV software, the company should be notified so they can update the signatures and work around it. Their reputation depends on it! (Of course there are also fake AV version floating around on the internet and with those all bets are off 🐵
Message 24 of 24
(1,388 Views)
