LabVIEW 2009 Freezing when using Ni845x.dll
LVexpert2b-
You may want to post on a different thread as this question doesn’t fit with the title “LabVIEW 2009 Freezing when using Ni845x.dll”.  However, I can confirm that the disable structure works in LabVIEW 2009.  Were there any particular VIs in your application that you can’t use transitioning from LabVIEW 8.6 to 2009?  Please either post back here or on a new thread.
Mike S
NI AE
Message 11 of 13
(683 Views)
Thanks George,
I already did create another thread under in Weird issues with LV2009 when downgrading project version.
I never had any problems in LV9 using disable structure or even in LV86.
Its just that when I downgraded from LV9 to LV86 the VIs always think that there have been changes due to "Disable structure switched frame".
In my new thread, an NI app eng. confirmed it as a known issue and they have CAR#147367.
Message 12 of 13
(671 Views)
LVexpert2b-
OK great.  I’m glad you got your answer.  Let us know if we can help with anything else in the future.
Mike S
NI AE
Message 13 of 13
(653 Views)
