LabVIEW 2010 64 bit Evaluation Download Error
After downloading the 890 MB file from NI, I ran the installer and received the following error:
Zip damaged: file c:\national instrument downloads\labview 64-bit\2010\products\labview64\part04\mib.cab: Bad CRC. Possible cause: file transfer error.
I repeated the download and got the same error.
Does NI know about this?
CB
Message 1 of 9
(6,919 Views)
CB,
Thank you for reporting this. After I saw this post, I went and downloaded the LabVIEW 2010 64 bit version on a Windows 7 PC. I didn't have any issues with the download. What OS are you trying to install LabVIEW 64 bit on? LabVIEW 64 bit is only compatible with Windows 7 x64, Windows Vista x64, and Windows Server 2008 R2 (64-bit).
If you are attempting to install it on an approved OS, can you post a screenshot of the error?
Stephanie A.
Americas Marketing Manager
Message 2 of 9
(6,894 Views)
StephanieO,
I am running a brand new installation of Windows 7 64-bit.  I should have been clearer: the problem is not in the download process.  It crops up during about 1/3 of the way through the unzip process for the downloaded file, 2010LV-64bit.exe.
The image is attached.
Thanks!
Message 3 of 9
(6,885 Views)
Rather than re-running the evaluation downloader, I found an installer on the NI site that worked correctly.  I'm good to go.
Message 4 of 9
(6,853 Views)
Thank you for letting us know. Just so we know, where you installing the bad version of LabVIEW 2010 x64 bit from?
Stephanie A.
Message 5 of 9
(6,845 Views)
Message 6 of 9
(6,831 Views)
I have the same problem.
The file mib.cab seems damaged during the download.
This is the error if I unzip with WINZIP.
I am in my company PC so there is the proxy/server/antivirus/firewall, and I don't know what else trhat can cause a problem,
This evening I'll download it from home and I'm sure everything will be fine.
Message 7 of 9
(6,622 Views)
In fact I was correct.
I downloaded the installation zip file from my home and it installs correctly.
To be correct, I am working with LV 2010 32 bit demo.
Message 8 of 9
(6,588 Views)
Same problem here,
Installed LV2010 eval at home, without any problems.
At work I got the same "Bad CRC" Error
Message 9 of 9
(6,027 Views)
