LabVIEW 2010 FPGA Driver for Xilinx SPARTAN 3E Starter Board
A new driver will be required. There were changes in LabVIEW 2011 that required some changes to the driver, and again in 2012
Message 31 of 36
(1,070 Views)
Ok, understood. thanks a lot for help 🙂
Message 32 of 36
(1,067 Views)
Hi:
I have the same problem than you. I cannot find the driver for the spartan 3e xilinx started board for LABview 2010. Could help with this and tell where can I find the driver?
Thank's for your help
Message 33 of 36
(1,014 Views)
Thank's. Now have other problem:
When I try compiling my program, I have this error---Erro code: -310601
NI-COBS: unable to detect cable communication.
I'm using a PC of 64 bits and I have this driver version:
Windriver: 8.1.1.0.
My PC detects the spartan 3E started board. But the the LABview 2010 cannot.  I go to Measurement and Automation Explorer but I cannot anything aboutXIlinx FPGA, there is only for NI Daq. I'm thinking that I need a USB driver for the spartan 3E started board.
Thank's for your help.
Message 35 of 36
(988 Views)
The issue is that the 2010 version of the driver does not support running on 64-bit OS's, you need to either run a 32-bit VM and pass the USB device to the VM, install a 32-bit OS, or upgrade to a 2011sp1 or newer version of the driver
Message 36 of 36
(984 Views)
