LabVIEW 2010 in-placeness crash bug
[cross-posted to LAVA]
I found an odd LabVIEW 2010 bug that will cause a hard crash. The bug appears to be related to how LabVIEW operates on data in-place and some interaction between clusters, arrays, and the Aum Array Elements node. It's hard to describe verbally, so I'll just draw you a picture :)
Attached Image: 2010 Crash.png
Attached File  LabVIEW 2010 CRASH.vi (16.56K)
Message 1 of 14
(5,044 Views)
No crash on my system: LV2010, W7 64-bit, Pentium E5200
Message 2 of 14
(5,013 Views)
Does not crash on my Mac.
Lynn
Message 3 of 14
(5,003 Views)
It crashes mine. No error messages, no nothing. Just bam, LabView is not running anymore.
LV 2010, Windows XP
[will work for kudos]
Message 4 of 14
(4,994 Views)
Jack: Are you running LabVIEW 64-bit or LabVIEW 32-bit on your W7 64-bit OS?
Message 5 of 14
(4,985 Views)
I'll add that I've seen this crash on LabVIEW 2010 32-bit (including with the 2010 f2 patch applied) on both Windows 7 64-bit and Windows XP (32-bit).  Note: I haven't tried LabVIEW 2010 64-bit.
Message 6 of 14
(4,981 Views)
I'm running LV2010 64-bit.
Message 7 of 14
(4,970 Views)
Hi Jim,
This was reported to R&D (# 252210) for further investigation.  It looks like you've pretty much covered this and the possible workarounds.  Thank you for being so thorough!
Jared S.
Applications Engineering
Message 8 of 14
(4,907 Views)
Could someone link where this has been covered well, with workarounds? I dont see a fix.
Message 9 of 14
(4,833 Views)
Jim linked a thread on LAVA. It appears he worked with NI support dirrectly since he reported a CAR number.
I know of no work-arounds aside from avoiding the data construct.
Ben
Message 10 of 14
(4,828 Views)
