LabVIEW 2010 in-placeness crash bug
@rex1030 wrote:
Could someone link where this has been covered well, with workarounds? I dont see a fix.
I don't have LV 2010 loaded (yet) but from the code shown above, I suspect an "always copy" node is worth trying to work-around the crash.
Use the CAR #
When we have a CAR# we can call support and get them to read off the notes. If there is a work-around it should be reported with the CAR#.
Ben
Message 11 of 14
(811 Views)
If you take a look at the VI which Jim included, there's a few different workarounds in disabled cases, including the always copy function and using a for loop to sum the elements in the array.
Jared S.
Applications Engineering
Message 12 of 14
(798 Views)
Update: I just tested this in LabVIEW 2010 SP1 and it seems to be fixed 🙂  The CAR Number (252210) is also in the list of LabVIEW 2010 Service Pack 1 Bug Fixes.  Thanks NI!
Message 13 of 14
(711 Views)
Cool, I did not notice that 2010SP1 has been posted. 🙂
Message 14 of 14
(694 Views)
