LabVIEW 2011 Development System fails to install
I have just tried several times to install my new copy of LabVIEW 2011 Dev Suite, but get an unknown exception (with no details - see attached picture) right at the start of installing the development system (English 32-bit).  I have rebooted and closed all applications including virus scanning but still the same.  I am using WinXP Pro SP3, and already have LV 8.6, 2009, and 2010 installed.  I'm completely baffled as this type of problem has never occurred before and there is no information about the cause of the exception.
Mike
Message 1 of 17
(5,450 Views)
Hi Mike,
Thank you for posting on our forums, could I initially ask what comes up once you click 'Details >>>' ?
I will be looking into this further for you.
Many Thanks,
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
Message 2 of 17
(5,407 Views)
Hi John,
After clicking on Details, the words "No information" or similar are displayed.  I have tried again today but with the same result.  I have attached a new screenshot showing the installer initialisation progress window.  I have checked the DVD and it looks undamaged, and there is plenty of free disk space.
Message 3 of 17
(5,398 Views)
Hi Mike,
Could you try initialising the installer on a different machine to see it if gives the same problem?
Also could I have the specs of your PC? If this problem persists I may have to escalate this further.
Many Thanks,
John McLaughlin
Message 4 of 17
(5,382 Views)
The installer does get further on another PC - as far as warning about low disk space.
My PC is a Dell Precision M6300 Core2 Duo with Win XP Pro SP3, 2GB RAM, 4GB free disk space.
Message 5 of 17
(5,361 Views)
Hi Mike,
This seems to suggest that it is a problem with the computer itself. I will look into this and ask my colleagues also.
Please ensure that all anti-virus software is closed also.
I will get back to you when there is progress, thank you for raising this issue.
Many thanks,
John McLaughlin
Message 6 of 17
(5,346 Views)
Hello, I just wanted to add that I have exactly the same problem while trying to install DIAdem 2011. Error Message and installer state is exactly as user Mike posted it. "Details" shows "No Details available" I also run Win XP Pro SP3. Also Avira Premium Security Suite, of which I disabled all "guards" with no success in terms of installation. I'll keep watching this thread and will answer questions as best as I can. Kind regards Herbert
Message 7 of 17
(5,296 Views)
Have you tried copying the installer sources of the DVD to harddrive before running the installer?
Also, Virusscanner or Firewall might be additional issues here....
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 8 of 17
(5,293 Views)
Hello Norbert, indeed I have tried all this: installer on DVD, on USB-stick, and the installer which comes with the download from the National Instruments site. Also I deactivated both Antivir and firewall. Unfortunately with no luck. Kind regards
Message 9 of 17
(5,281 Views)
Same issue here  XP SP3 (all up to date).
Message 10 of 17
(5,231 Views)
