customize multiple Y scales in one wave graph
  I am trying to show two channels in the same waveform graph but with seperate Y scales. And I want to customize the two Y scales independently using property nodes. But I found under the waveform graph property node there is only one Y scale.
  Does anyone have the experience to customize them independently using property nodes?
XP\LabVIEW 2011
(2,728 Views)
Accepted by topic author Exia
Use the property "Active Y Scale" to select the scale you want to act upon.
Set Active Y scale to 0 (the first Y scale), then set all the properties as you wish for that 1st Y scalethen set Active Y scale to 1 (the second Y scale) and again set all the properties you wish for that 2nd Y scale.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,726 Views)
It worked perfectly. Thank you very much.
(2,714 Views)
